I've recently replaced an interior door (big old 50mm thick thing that was warped) with a new cheap moulded door. It's between a hot living room and a cold porch. Door was primed and has 2 coats of paint on to stop any moisture getting in. It seems that this door has now warped too, I suspect due to the difference in temperature between the two rooms. It now catches on the frame unless you push it from one side whilst closing it. Is there any way to avoid this happening or to fix the problem (it gets better sometimes but definitely worse if I light the stove in the living room and make it really warm). The door currently has two hinges but I was thinking about putting a third one in the middle which might help but isn't really a cure.
Any suggestions or are there any doors that I can get that won't warp like this?
Thanks.
Thanks.
