Hi People!
OK, as usual novice alert!
A radiator downstairs has a faulty isolation valve attached to the feed pipe (it is dripping water). I have a new one, but am unsure how to turn off the water supply through this pipe to the radiator, so that I can remove faulty valve and replace. I have found 2 red wheels in the airing cupboard and turning these off shuts down the cold and hot water to the taps. Do I just run the taps and this stops the flow to the radiators too? I ask this as I did so and turned the faulty valve back on and it still leaked.....not sure if this is just the water left in the pipe as it is a slow leak....
Any help much appreciated!
