Hi thanks for looking
I moved my storage heater creda tsr24aw and the front insulation panel broke. I couldn't find a direct replacement so I installed a thermal mat type heat shield.
I also replaced one of the elements which although it's a direct replacement there is a slight height difference compared to the others
Now when I put the heater on it will work for 2-3 days then switch off. I can then reset the thermal cut-out and it comes back on.
So is it the insulation or lack there of? The element? Or the thermal cut out switch.
Thanks in advance.
Thanks in advance.
