Storage Heater Timer
7 Jan 2010
Stirlingshire
It's getting to that time of year when my storage heaters need turned back on however one in the bedroom is giving off too much heat during the night.
The heater is on an ecomomy 7 circuit but i want to reduce is to maybe 3 hours during the night.
I want to put an additional timer on the bedroom heater spur which has a 15A fuse.
Would the following do the job?
http://uk.rs-online.com/web/search/searchBrowseAction.html?method=getProduct&R=5129594&cm_vc=av_uk
or this one
http://cgi.ebay.co.uk/SMITHS-TIMEGU...arden_Hearing_Cooling_Air&hash=item3f037986db
Many thanks
If you have an off peak supply for the storage heaters, which you almost certainly will, the timer will not have a permanent supply to keep the clock going.
Can't you turn the setting down, or fit a smaller heater?
yup its on a off peak circuit. Thats a good point i didnt consider.
The problem is that in order to get it the heater to give enough heat during the day it means the heater has to get very hot over night.
Can you get timers that run without a constant current? Failing that I guess i need to accept i need to buy a new storage heater with better heat insulation.
You have limited options. The problem with storage rads is they need to get good and hot (at night) so they can dissipate their heat during the day.
If you want heat in your bedroom during the day then a storage rad is the better option. But a new one, the latest Dimplex range have much better heat in and out controls.
If you do not need heat in the bedroom during the day then get rid of it altogether and install a panel heater with a timer, connected to the 24-hour supply. You can then have heat at scheduled times and turn it on when you want to watch the rugby while tucked up in bed...
You can still use the timer - set the OFF to three hours after the ON, then it'll switch on when the power comes on and switch off three hours later. Of course you'll have to remember to reset it every evening so it works the same the next day ....
PJ
