storage heaters
18 Oct 2007
London
i was asked to organise the installation of new storage heaters. it's a simple job of replacing like-for-like. however, my spark does not know how he is supposed to test the heaters once they're installed as they run on economy7 electricity.... does that mean he has to come round to carry out a test after economy7 has kicked in? i.e. around midnight...!
unfortunately there is not a lot of info about storage heaters. what does one have to look out for when installing, testing, etc. can someone enlighten me?
thanks for your time
The only live tests are loop impedace, which can be calcultated from the Ze + (R1 + R2), and then RCD - And unless you have a TT earthing arrangement, there will be no RCD. Polarity will be proved when you measure the R1 + R2.
Simple ;)
Though surely the Ze could be different on the storage heater supply, particularlly if it is on a different phase.
Ask DNO for an isolator and and connect the off peak tails to the 24hr side just for testing?
thanks for the tips, any other info on storage heater installation?
much appreciated
This is the prefered method. You could also take the Ze as the max declarable - 0.35 or 0.8 for TN-C-S and TN-S respectively.
much appreciated
Yeah... watch your back! and the carpet. the brick dust has an annoying habbit of going everywhere! Don't forget to cut out and carpet and gripper rod that the legs might sit on as this will make the thing unbalanced.
