I have three of these, 1 on 1 fuse and 2 on another! The fuse that has 2 on has gone twice now! They are the old wired fuses and the heaters were put in by the person who used to live there although he only replaced old ones!
The total Amps of the 2 heaters is around 18 Amps but it is only a 15Amp fuse, which is why it keeps blowing the fuse. So the question is can I up the fuse wire to something like 20 Amps? An electrician where I work reakons I should go to 30 Amps!
The cable from the isolator switch which included the fuses is 4mm 3 core cable (gray and flat) and then from the fuse spurs to the heaters is normal white 3 core flex!
