Hi everyone,
I have just bought my first house, built in 1979, it has a cold system attic, currently with about 150mm glass mineral wool style insulation laid between 100mm high joists (about 35mm wide). I'd like to increase the insulation but also add some much needed storage space. I've read up a lot on this subject and am well familiar with the various systems available. But before I launch into my preferred option I'd like to get opinions from fellow diy'ers or tradesmen on whether it sounds like a good idea or not.
The loft joists are fairly standard and therefore not designed to carry heavy load, so I'd like to keep the weight down. With that in mind I thought I would avoid adding cross battens, extra insulation roll and then chipboarding over the top as that seems like quite a lot of additional weight with all the cross joists/battens.
I could use loft stilts/ loft legs, extra insulation roll and then chipboard, but this seems like quite a lot of effort as by my calculations, for the area I want to board between the trusses would require 110 stilts in total.
I like the idea of using 100mm kingspan, laid directly cross over the joists (yes I know this would compress the existing 150mm wool roll which is a bad thing), giving a total of 100mm wool roll (after compression) and 100mm kingspan, which has an insulating equivalent of 200mm of insulation roll or more, bringing me up to 300mm. I would then lay chipboard directly on the kingspan and screw through both into the joists. Building savvy friends have said the kingspan is pretty good under compression and shouldn't damage too much just from having light storage boxes placed on top (nothing too heavy) and occasional foot traffic. The weight shoukd also be spread out from the chipboard on top right?
Seconds and co are selling 100mm kingspan at the moment at a price that would make the whole job only around £100 more than the loft roll and stilts option, and in my mind it should be a lot easier to do and I get to keep about 100mm more headroom in the loft by using kingspan.
I don't think I should need to worry too much about trapped condensation as the kingspan is not foil backed, so hopefully any rising vapour will permeate as before and it will only be laid in the middle of the loft, with more wool roll laid either side towards the eaves, so air should be able to circulate under the kingspan from the sides.
I know the kingspan will crush slightly on the ends where the weight above is held by the edges overlapping the joists, has anyone tried this method and has anyone found this to be a problem?
What about down lights to the rooms below, would I need to put metal diffusers round them before the kingspan goes over the top, leave a hole in the kingspan above them or box them in somehow?
I'm interested to hear peoples thoughts in general about this solution and especially if anyone has done this themselves.
Thanks[/u]
Thanks[/u]
