Stormdry (or other sealants) on cavity walls?
4 Mar 2024
From research it looks like Stormdry could be useful for single skin walls, but I've not seen whether it would be much use on cavity walls - does anyone have any thoughts? We don't have any damp issues internally, but the walls/house is very cold (and I don't want to go down the cavity/internal/external wall insulation routes). Thanks
It will work on any brick work
I suppose there’s no harm in trying it, but I can’t it having any material affect on temperature of the internal face.
If you are serious about wanting to reduce the house being so cold you might want to consider buying a thermal imaging camera which will show you where the cold is creeping in - you might find draughts and thermal bridging are causing heat loss.
Thanks, that's helpful. I've had thermal imaging done previously and it didn't show any major areas, just the usual door/window frames (which I'm sealing up). It feels like a more fundamental issue, but I don't really want to spend £££ or risk cavity wall..
