Stove and back boiler to do hot water and central heating
5 May 2010
Bristol
im thinking of having the above work done at my house but want to g
et my head around it!
basically do i have the following
flow and return off back boiler (opposite ends of boiler for F+R) pump on the flow sraight away then just pipe up system as normal?
then for hot water
flow and return to rad dump then to F+R to cylinder with a stat to control temperature of water
hot off top, upto vent in F+e tank and down for hot water
what other valves need to be put into place
what if i want just hot water and not central heating, do they just wire it up so that pump doesnt kick in?!
thanks
Bruce
I am N A F M R!
Did you even mention what you intend fitting?
Different appliances have different requirements.
Some have two tappings and use an injector tee, Others have four tappings.
Either way they must be installed as M I's.
And YES I do!!!
ha ha, lets make it clear im not installing it i would just like to know a bit about how it works!
it has 4 tappings!
so in the manufacturers instructions it ill have everything in it on how to install the hot water and central heating side?!
cheers :D :D
smile
