- Joined
- 7 Feb 2010
- Messages
- 3,009
- Reaction score
- 332
- Country
Can anyone suggest a suitable board material to fix tiles, to, and attach to a wall behind a wood-burning stove?
We had our stove installed earlier this year. It stands in a corner, on a hearth of 9 inch pammets. The wall behind was re-skimmed not many weeks before the stove was installed. Although the stove is a good 6 inches from the wall, I noticed last night that the plaster is cracking, and about to blow off the wall.
I want to avoid removing the stove, so there isn't access to render the wall. I thought of attaching tiles to a board, sliding the board behind the stove (there is clear access from one side), and sticking to the wall with tile adhesive, to cover the damaged area. I imagine it would be advantageous to fix the tiles to the board with a cementitious adhesive. Can anyone suggest a suitable material for the board, or alternatively something I could use without fixing tiles to it? I don't want it to look too modern, otherwise I'd consider a sheet of zinc or aluminium.
The plaster is only cracking up to the height of the stove itself, and not behind the exposed flue pipe. So the solution only has to be the height of the stove.
Cheers
Richard
Cheers
Richard
