We've just had a new hearth and wood burning stove installed by hetas approved installer and the day after the stove has been on there appears to be quite a lot of water under the hearth that evaporates over the next couple of days.
It is a Victorian terrace and when moving furniture for the install we noticed damp in the corner of the room and got it sorted, replastered about 3 months ago.
The stove was being installed in the existing alcove where we had removed the old fire and put laminate down. The laminate was cut back to the old sub base and the hearth was made at the stove shop's workshop and then laid over the old base and the front of the hearth overlaps the laminate by a boards width. There is a gap between bottom of hearth and laminate of nearly 10mm (to the right, smaller to left).
The water appears under the hearth and not on top. The installer thinks we have a leak so I lifted the laminate and floorboards and subfloor is dry in front of hearth. Subfloor is quite shallow. Where we had the damp the subfloor is moist and looks like damp in timbers so damp company came back and recommended some remedial work. But they say subfloor will always have moisture and think our stove issue is unrelated.
What they think is the bottom of the hearth is cold, the top of the old base is cold, a small gap in between them that warms up when stove is on and no circulation is causing condensation. Could that be the explanation?
If so has the stove been installed incorrectly? Should there be no laminate under and instead the whole gap should have concrete in it? Could we remedy it without removing the stove and hearth?
Cheers
John
Cheers
John
