I am fitting a wood burning stove into an existing fireplace. The chimney has been swept and smoke bombed and confirmed I don't need a liner. Building Control have been out and confirmed they will sign off the stove as part of my kitchen extension.
I have bolted angle iron brackets inside the chimney and now I need to sort out a Register plate to fix to them.
I understand that the plate should be 1.5mm galvanised steel and I am thinking of buying one ready fabricated off eBay and cutting it to size. The Flue pipe is 5" diameter. The last time I saw a register plate (which was in mild steel) it had an upstand welded around the flue opening to enable a rope seal to be pressed in. However it appears that galvanised register plates available ready made do not have an upstand around the flue hole. Something to do with welding Galvanised is a pita.
I could make an upstand myself from mild steel and pop rivet it in place or is there another way I can seal around the flue pipe as it passes through the register plate ? eg; any kind of flexible sealant ?
Also, what's the preferred way of sealing around the edge of the register plate where it fastens to the angle iron / brickwork ? Fire cement or some sort of flexible sealant ?
thanks
thanks
