Stoves cooker
28 Nov 2005
Hi Chaps
Have a stoves electric cooker that trips the mcb when you turn on a particular ring. The heater element, hot plate and switch / thermostat are all listed as spare parts.
Could any of you chaps help me with what to test (can use a multi meter) to avoid buying the whole lot as parts when its either the element or switch / thermostat
Most likely to be the element,can you disconnect it and insulate the connections then switch on controls and see if fault has cleared.
