I have a stoves gas oven which is not working properly. It usually lights first time but will not relight immediately if I have to turn the oven off before opening the door to check the dinner. It will usually relight if I leave it for 10 mins or so. The gas is coming through as I can smell it but there is no spark from the ignition. Is this likely to be an expensive or complex repair, the oven is around 17 years old.
Thank you
Thank you
