straighten a woodworkers brace...
3 Jan 2009
How would you go about straightening a Stanley model No: 73-12-IN-Mk4 brace?
If the brace is stood vertically the higher crossbar is not aligned with the lower cross bar by perhaps 1/8 inch.
So when trying to drill or screw the top of the handle will move in a circle while the user fights to keep the screw bit in the screw slot.
I do not have a metalworkers vice which I would like to have for another attempt to straighten the brace.
I did try with outher tools but realized steel is hard....that's a joke I suppose...
It seemed to bend and I was sure I felt it bend but attempts to use the brace revealled no change.
Just in passing I wondered if anyone had a good idea as to how to staighten the brace.
I could keep it and use it , it can still drill a straight hole but it is awkward to using it as it is.
Hi Wigs
I cant find the exact model you describe but there are several Stanley Braces on ebay. I imagine it has bent on on of the bends next to the handle (I cant imagine how you bent it other than running over it with a tank). As a retired maintenance fitter I think you would need a good solid vice & alot of heat (oxy bottles) Which unfortunately would damage the handle, Sorry I think the job is a NO NO.
Good luck
JonB
