Hi all
When I bought my house I was told it had been rewired in 1987. However there is quite a bit of stranded PVC/copper cable on the socket circuits [edit - just found some tinned copper / ally as well], and junction boxes under floorboards. When I have found a junction box under the floor, I have made an access panel in the floorboard fixed with screws, and relaid the carpet. There is no VIR cable.
I have also found that some parts of the lighting circuit have had no earth, these have mostly been replaced and I will do the last bit in the summer hopefully. I have checked for earth continuity back to the CU on parts I have replaced.
I have a TT system with whole house 30mA RCD and 7 Wylex NSB MCBs. All 16A radials apart from the lighting circuit which is 6A.
I can only conclude that the work in 1987 was not a full rewire but just a replacement CU and new RCD.
I would like to change my CU for one with 7 RCBO's in place of the RCD+MCBs.
Which leads on to the question: Is it certain that my house will require a full rewire if I wish to change my consumer unit?
Many thanks,
mogget.
Many thanks,
mogget.
