Got a strange extra fuse box and can't work it out..
Box on the left has fuses and is supplying power to everything in the house.
Box on the right (one shown close up) is connected with tails BUT no fuses and turned off. Looking at it two of the fuse blocks are connected to cables which go straight into the wall behind, there is a 3rd cable which is looped across to the left hand fuse box.
It looks like the right hand box was an old box and the left hand one a newer to provide more seperation BUT where do the two cables behind the left fuse box go??? How would you work it out??
Also I only have one set of tails from the meter BUT two into fuse boxes - would these be split in the wall cavity??
Cheers for any thoughts
Rob
Rob
