Hi
Could anyone please suggest a reason for the noise in my heating.
Basically when its turned on its quiet for about 30mins and then it starts droning. The drone gets louder and then stays for the duration of the heating being on. Its a kind of constant drone.
Ive listened at the pump and the pump sounds to be quiet. Ive also adjusted the pump speed and it doesnt seem to affect the noise.
The motorized valve has recently been replaced (on a seperate issue) and this didnt seem to have an affect on the noise. Weve also had a new hot water cylinder in the last year and that didnt affect things.
The pipes are all plastic if that makes any difference??
Also weve just had the boiler services and so thats all okay.
What seems odd is that when we turned the TRV in the bedroom up from 3 to 5 the noise went away (suggesting maybe less pressure or more flow through the system) and came back if we lowered it back to 3.
BUT when we then left the bedroom on 5 and lowered the hallway rad from 4 to 3 the noise came back???
So we left them on the settings where it was quiet and then after about 15mins the noise started coming back of its own accord.
The noise also seems to alter a bit in pitch if we alter it between heating/water/both.
We have a sealed system off of a standard non-combi boiler. The pressure is set generally at about 1.7bar.
We do seem to loose about 0.1bar about every 6-8 weeks or so.
Another odditty is that the loop radiator (with no TRV) always seems to need a tiny bit of bleeding on it no matter how many times we have done it. Its only ever a tiny tiny amount but seems odd that in a pressurised system im not sure where the air is coming from, surely it would all be out of the system after refilling at about third week after bleeding every 4 days or so??
Anyway, after all that lot, I do hope that somebody can offer any thoughts as to what could be the cause. The drone is annoying during the day but in the morning it actually wakes us up which is awfull.
Many thanks for all who take the time to read this and also many thanks for any thoughts that may be able to help.
Cheers
Bobspoons
Cheers
Bobspoons
