I'm hoping somebody could suggest a solution to my heating issue.
My house has a Ravenheat rsf 820/20 boiler that is set to come on automatically for a few hours each morning, and then should come on in the evening but isn't doing so. Here are the details of what it does:
The heating comes on in the morning (6:30am - 7:30am).
The 'On' light comes on at the right time in the evening but the heating doesn't come on (18:30 - 21:00).
The 'Manual' setting also switches the light on but doesn't heat up.
The pilot light is on.
The pressure gauge was under 1 but I've now raised it to 1.5.
The boiler is set to heating and water.
The water heats up at all times.
The timer is set correctly.
I have tried switching the boiler off and on, and resetting the timer unit but it hasn't resolved the issue. I guess it's a timer issue as the heating works in the morning, but then the manual switch doesn't fire it up, and the red 'On' light coming on at the correct time in the evening suggests the timer is working to some degree.
Any help would be greatly appreciated as I'm sat in two coats until my landlord gets a plumber to fix it!
