Strange noise when using hot water
10 Aug 2010
Leicester
Hi we've a strange noise (foghorn) which seems to happen when we switch the shower on (mira react thermostatic bar valve) or the hot water tap on first thing or when we've not used the hot water for some time
Any idea what it could be it seems to last a few seconds
Boilers a ideal logic 15 and the cyclinder tank is a indirect 150l
Most likely a worn float valve in your loft, assuming you have a hot water cylinder
I don't think there's anything in the loft
Nor do I now you've posted that! Could be a problem with the control valve, you'll need a G3-registered engineer to look at that
Managed to get a video of the problem
Been told it's diaphragm in the white expansion vessel vibrating when hot water is drawn
Trying to find a G3 engineer in Leicester is hard!
