Hi.
We have a small room at the end of our landing with loft access that we use for the cat's bits and pieces.
The loft light is connected in some way to the light in this room.
Recently, the light has stopped working in there. It initially manifested itself as coming on, then going off. It then started working again but the switch was now working the wrong way round.
This light no longer works at all.
Now the problem has spread to the landing. This light mostly works but changes daily from on turning the light off and vice versa. This light too also decides to stop working every couple of days for a few hours.
There is no observable pattern to why the function of the switch but none of the other upstairs rooms have problems.
We spend a lot more time in the loft now as it is going to be used as a cat nursery.
Perhaps our constant walking around has caused some sort of bad connection?
The loft light is also fine.
I would like to get an idea of what could be causing this before I call out an electrician in the run up to Xmas.
Assuming I pull the loft boards up in advance, what do you think the time and therefore cost is likely to be?
Thanks a lot.
Thanks a lot.
