Hi, hope someone here can help.
Recently my phone stopped working properly (not ringing continuously when someone calls) and my broadband kept dropping out. It deteriorated until the line was totally dead (no dial tone). Suspecting it was due to the old extension socket, i fitted a new one and sure enough, everything then worked perfectly - for a day or so.
It then re-occured, which i couldn't understand, so i fitted a new master NTE5 socket. Again everything then worked perfectly so i know it was all wired up correctly. But 24 hours later, the problem came back again and the line eventually went dead! - despite the fact that by this point none on the old wiring or sockets remained.
If i plug the phone into the incoming test line, it works fine, but if it's plugged into the faceplate socket (or extension) the line is dead. so why did it work for a day or so? It's as if the new sockets are getting 'fried' somehow. What on earth could be causing this? Even if BT fitted a new master socket themselves, what's to stop it happening again?
