strange question - how to find type of wall
29 Apr 2012
London
hi
i am trying to find out which type of wall (e.g. solid) in one of the bedrooms so i can get an idea if a floating shelf is suitable
i dont have any stud finder etc devices and by simply tapping i am not sure if i can tell. maybe the location of wall itself may shade some light.
house is 1950s built. If you can think of 3-bed semi detached hose. as we enter the house, its a hallway with stairs leading upstairs. directly above the hallway is a small bedroom. The wall i am trying to find out is the bedroom vertical wall which stops above the stairs.
i am not sure if i have explained this properly but i hope it makes sense.
ta
A 1950s house will almost always be solid walls, the best way to tell would be to knock on the wall if it sounds hollow then it will be a stud wall, another way would be to get a thin tool such as a screw driver and tap it with a hammer If it is a stud wall you will go right through, make sure your not inline with any sockets or light fitting/switches
thanks. i will try that.
just had a friend around who says its a dry wall. like someone mentioned i was under the impression that most of 1950s houses have solid wall so a bit surpirsed,
but i unfortunately still dont know if its dry wall for sure. tapping on the wall iseems to make hollow sound!
ta
Knocking on one of your exterior walls (assuming they're solid) will sound solid compared to a stud, they will sound totally different.
Although as stated many 1950s houses have solid walls, it is quite usual to find the wall over the stairs to be "hollow" to avoid having to install a lintel to support it over the stairway. A hefty bit of timber could support a lath and plaster wall (or modern plasterboard)
is there a confirmed way to find out type of wall other than sound or drilling test hole? i may be asking stupid question here.
You also could have a brick wall with dot and dab on supposed to render and a skim. Which can sound hollow in places where there is no adhesive. I think your best bet would be to pick the spot where you want the shelf then drill a small hole and see if you hit brick
dot n dab in the 50's? :rolleyes:
If he can't determine if a wall is stud or masonry God help the OP with whatever it is he will be attempting.
I am sure you are very good at everything you are doing. dont waste your time looking at comments from people like me. thanks for nothing then, i will get help from this and other forums rather than troubling GOD.
