After partial drain down to replace a leaking valve on upstairs rad , found that after refilling etc one rad downstairs stays cold , pipe to it gets hot until about 1 meter from rad . Iv removed rad to flush out also opened both valves to check not faulty, both fine .. I'm thinking could it be the pump not up to job as other rads heat up fine only the one .. Any ideas appreciated befor I spend on new pump .. Thanks
