I am trying to replace a part on my shower - should be a very simple job, but it's turning out to be a complete nightmare.
The problem is that all of the parts of the shower are held in place by hex screws that none of my hex keys fit. I have full standard metric and imperial sets so there shouldn't be a problem but the 2mm metric key is too small and the 3/32 inch imperial key (which translates to 2.38mm) is too large.
To make things even stranger, the spare part I bought from the manufacturer has a new hex screw for fitting the part and the 2.5mm key fits it without any problem.
Does anyone have any idea what is going on here or how I can get this part fitted? Is there an obscure size of hex key available that will fit these screws or have the screws shrunk in the shower!? (only half kidding!).
Could I take a drastic measure and forcibly remove/drill out the screw that is holding the part in place (I only need to remove one screw and I could use the replacement that came with the spare).
Not sure if this is a good idea, but I really need to get this fixed so any help you can give would be greatly appreciated.
