Hello People, wonder if you can help?
I have got a fault on a smoke detector circuit... wired 1.0 t+e from cu to 1st smoke then 3 core up to next smoke. IR tested and clear on every cable to N and to CPC and to eachother
When you put power on with no smoke heads up it holds.
When you put one smoke head on it trips one RCD
When you put the other head on it trips both RCD's
I tested where the cables go and they are definitely the right cables. There are no crossed Neutrals in the CU and i tried the smoke heads in different properties and they are fine.
So now im stumped any ideas? Thanks anyone who reads/replies...
