Help, I'm doing up a 1930's semi which I currently have stripped back to the brick inside. It is of 'solid' wall construction in so much as there is only a mortar width (12mm) gap between the inner and outer leaf of the brick wall, but I am worried about the quality of the brickwork which although perfect and crack free internally, has many fine cracks through both bricks and render on the outer leaf.
The reason for my worry is that there seems to be too few headers compared to stretchers in the brickwork: It has approx 54 courses of bricks and only 5 are full rows of headers with the rest being full rows of stretchers. The courses of headers are not even evenly spaced; there are 18 consecutive courses of stretchers at one point.
Does this sound either iffy or familiar to anybody out there? I was wondering about fitting some sort of remedial wall ties (resin or compression fit to make up for the lack of headers, and then making repairs to the outer wall before re-rendering internally and externally. Can anybody offer advice, and do remedial ties for solid walls actually exist?
