take a note of my signature, AND mark the cables, put up 1st flourescent light and connect it as per drawing you now have, use choc bloc (connector strip) for the 3 red wires.
then put up 2nd flourescent light, run a 1.5mm twin and earth from 2nd light to first light, connect it in 1st light to same terminals in the light that you did in the 2nd light
you will of course turn the mains OFF while you do all this
