We moved into our place a few months ago and we’ve finally made a start on trying to sort out the terribly unpleasant wallpaper in the bedrooms. From the rest of this post it will be pretty obvious that we don’t know very much about decorating!
We stripped off the first layer of lovely textured wallpaper with a bit of water and a bottle of wallpaper stripper – simple. The next thinner layer was trickier but eventually we got all of the paper off the walls. But now we’re faced with plaster walls which are covered in patches of a thin coat of yellow paint. We want to paint the walls a nice simple white, so we made a start on trying to get this paint off to get an even surface.
Scraping was damaging the plaster so we’ve been sanding away with our pathetic little sanding machine. I’m worried that we’re starting to damage the surface of the plaster with the sanding (180 grit paper). Is there an easier way to do this? I’m worried if we used a stronger sander we would damage the plaster and have to pay for a skim.
Once we’ve got the paint off, filled the cracks etc. what is the best procedure for repainting? Some places suggest PVA, some talk about watering down paint, others suggest some sort of primer for the plaster. I’m totally confused. I just want a nice simple white wall.
Any advice would be very welcome!
