Stripping down painted copper pipes
20 Jan 2008
Merseyside
I have several 22mm copper pipes in my central heating system that I need to cut into to clean due to blockages. The pipes have previously been painted with what looks like a metallic paint or finish and are located in the airing cupboard. Any advice on removing the paint especially the part of the pipes that will remain and therefore difficult to get behind to clean
Lightly grip the pipe with pump pliers, at the point where you intended to cut it. Turn the pliers to start removing chunks of paint. Repeat if necessary.
If any paint remains, clean it off with wire wool.
Cut pipe.
