Hi
We have decided to go back in time and instead of having fully fitted carpet, have a stair runner. Problem is the paint that on either side of the stairs is lifting and cracked so needs to be removed.
I went out today and spent £12 quid on a lead paint test kit, which when I used it showed a bright red result meaning the paint is lead based.
I presume the only way to get this off is to use a wet stripper ?. Also once I've got it off are you safe to use a sander etc on it or is the contamination deep in the wood.
Maybe I'm being to careful - after all I grew up in a house with lead water pipes so have probably been drinking the stuff for years!
As always, any advice would be much appreciated
