D
D.I.Y-SI
Hi all, Just had a new combi boiler fitted and need to remove old solar system. Had hoped i could just drain down and dismantle but in the loft where the pump and expansion vessle are located there seems to be some sort of liquid in the system. If i undo all the pipes up there will there be much of this liquid to come out? It looks like a very thin oil yellow in colour(anti freeze may be?). The system has an open vented tank with an Evacuated tube panel and pump. There are two pipes going from the panel to the cylinder tank in kitchen. Do these carry water or heated fluid from the panel to the tank and heat the water that way? Sorry for my ignorants but need the system removing asap.
Thanks for any help!!
