Stripping steps on my stairs
15 Feb 2014
London
Hi all
I've used paint stripping gel to remove white paint from the steps of my stairs (still needs work but it's getting there)...
The middle of the stairs were originally covered with carpet so as you can see from the pic the wood colouring is different, but I'd like to keep the steps in the light wood colour...any idea what I could do? Is there any way to do this or do I have to paint them, or varnish them a dark colour?
You could use wood bleach to lighten the centre , but are you leaving bare?
Thanks - the aim was to leave the whole thing bare, yes.
Would that work with wood bleach?
Yes. I've used it quite a few times to remove iron and other stains from timbers, particularly oak. You buy it as crystals and make it up to the required strength. Ideally pre sand the stairs to about 180 or 220 grit, dampen the timbers to raise the grain, allow to dry thoroughly (at least overnight), cut back once more with the sand paper and finally apply (remembering that whilst weakish this is still an acid so gloves, goggles and a mask are highly advisable). Make sure to blend in any drips, etc quickly to avoid uneven bleaching and leave to dry. This helps get a consistent result
Once dry if the bleaching is still insufficient the surface can be remanded (same grit) and bleached. Repeat until you are happy with the colour. Once you are done neutralise the z I'd with a very weak coat of something like caustic soda (and I emphasise VERY weak). Leave to dry and resand
Bleached too much? Then resand, neutralise (as above), sand again, and to e in using one or more coats of a water based wood dye, diluted as required. Multiple watered down coats to build to a colour are easier to control
And yes it really is apply, let dry then sand all the way through EXCEPT if when you need to re-use
Edited to add more detail
