Hi, I'm working on stripping my wooden bannisters which were gloss painted by previous occupants - a crime I reckon! I've got reasonably far but I need some expert advice on two tricky bits.
Here is a general photo of the bannisters in their current unfinished state:
The first problem: I've used several coats of paint stripper (Nitromors) and some sanding to get off the paint so far but you can see some white paint still left in the grain - particularly towards the bottom left of that panel. I can't seem to get this out.
My current plan would be to finish the bannisters using medium coloured danish oil - but this will make the white bits stand out more. Should I try and persevere with the paint stripper, use another method, or accept that I might not get it all out and pick a suitable finish to help disguise the remainder?
The second problem:
That is the top of the bannisters and I can barely get my hand in and it's hard to get enough leverage with a paint scraper. Any good tips for getting the paint out of there? It was hard enough doing it on the panels that I had easy access to!
All advice very gratefully received!
The second problem:
