- Joined
- 9 Dec 2023
- Messages
- 1
- Reaction score
- 0
- Country
I've just moved into a property that uses downlight LED in the main area, and I get a significant strobe effect from these lights (most noticeable when waving hands or any other fast movements under the light).
The lights are AU-FRLD811, and they were installed with a leading-edge dimmer, so I was wondering if that could be the reason.
I couldn't find a proper spec sheet for this light from Aurora. Various resellers seem to indicate that the AU-FRLD811/40 model is expected to work with both leading/trailing edge dimming (e.g. https://sparkshop.co.uk/aurora-ligh...able-led-downlight-fire-protection-4000k.html), but I haven't found a similar statement for AU-FRLD811/30.
I temporarily used a dimmer I have in another room, a Varilight V-PRO LED dimmer. When paired with a basic cheap LED bulb, this dimmer works flawlessly: full range dimming, no noise, no flickering, no strobe effect.
Sadly, when using the same dimmer (in trailing-edge mode) on the AU-FRLD811, and the strobe effect is still visible (although I think the buzzing noise I was getting with the other dimmer is reduced a lot).
I'm quite surprised this effect is here and so pronounced, as I'm used to flicker/strobe-free LED lighting with the Philips Hue range. Is this expected? What are my options here?
