- Joined
- 10 Aug 2015
- Messages
- 1
- Reaction score
- 0
- Country
Hi all,
(I have tried looking but could not find this subject covered in another thread, if I am mistaken please point me to the correct thread and I will try to cancel this posting)
Replacing a small 3sqm washroom with a wetroom, and contemplating the use of Hardie's 22mm structural board hardiefloor (Structural Fibre Cement Interior Flooring - hardiefloor in a bid to achieve levelling with existing floorboards in the neighbouring room and the 22mm Impey wetdec former. Would most appreciate some advice with the following:
Does anyone have any experiences to share or recommendation on regarding the product and proposed application?.
The plan is to:
Any other advice or highlighting of missed steps would be appreciated.
Given the small area I intend to waterproof full length of all walls. But as yet have not decided on which route to take. E.g. Hardie or aquapanel with membrane or wedi/marmox setup.
Thanks in advance
The plan is to:
- Strengthen joist work (trimmers/noggins screwed with 10*4 or 12*4 spax quality screws).
- Lay insulation between joists any recommendation on which insulation.
- Replace an existing aav heading into the attic with an A1 AAV raised to 200mm above the highest wet entry's centre line - this aav will fit within the joist space.
- Fix hardiefloor - (spax quality 50mm screws at 100-200mm intervals, 25mm from t&g edges, 12mm from butt edges + gripfill type adhesive on joists and silicone sealant on t&g ends and screw heads).
- Apply tanking membrane (preparing hardiefloor according to chosen tanking system e.g. Priming)- was planning on using impey's tilesafe but given its vertical tile load and heating limits i am looking for alternatives - perhaps impey's waterguard, i will be going through other threads on this forum to understand different tanking membranes.
- Securely fix rcd protected uht (compatible with the chosen tanking membrane) any recommendations for uht systems?
- Consider applying (depending on the robustness of the uht mats) slc for general floor area and slurry of rapid setting flexible tile adhesive on former tray.
Thanks in advance
