Currently having an extension built 8m in length and 3m wide. Iv asked the SE to remove the wall between extension and the old house, and a beam for the new extension back wall where im installing bifold doors. He has advised a 305x305x97kg uc on 550mm piers of exsisting wall.He then advised the same UC in the extension back wall where i am having approx 7m of bifolds.
I am just concerned on two things:
1. The orignal house is wall is 250mm inc cavity, why would he suggest a 305UC97 and not a 254uc? It is a standard two storey house.
2.why he is suggesting the same beam for the new extesnsion back wall where the liad is only of a 8mx3mx tiled toof? I am however having bifolds across this wall and he mentioned something about deflection and causing problems with the bufold doors in the future.
I was thinking of getting another SE to calculate and compare but thought i would ask for some advise before i do, the 305UC97 is nearly 750kg in total so want to be sure its correct before i commit to a crane!
Any help is appreciated.
Ap
Ap
