Hi, I am in the process of planning the fitting of a ceiling mounted disabled lifting hoist and the room it is going in has a ceiling constructed of only 3 x 2 timbers on the rear addition of a Victorian house with a pitched red concrete tiled roof above. I need to create some additional support in the ceiling void to spread the loading that the hoist will impose when used. After the addition of some sort of spreader over the joists can I also attach strapping to the angled timbers of the roof above from the 3 x 2 ceiling joists to create additional support and further spread the load? If I was to do it what process and materials should I use?
