Struggling to get WB PRV off
14 May 2007
Manchester
Sorry to post as new topic...but I am really struggling to get the PRV off.
Does anyone know how to get the PRV off this worcester bosch
I have taken the clips out but I can't seem to get it off. So far I have been what I described as being quite delicate with it trying not to rip it apart.
Do I pull it off? - I don't want to tug on it too hard
It looks like the right side of the PRV joins onto a push fit elbow?
I have drained the water out of the PRV
Attached is a pic of the prv again
Thank you
Don't know this particular one but is there a grub screw holding it on at the base?
I dont think so gas, sure its just a retaining clip but they can be a nuisence to get out
the outlet usually holds it in place so I would get that out first, I have had to cut the OUTLET!!! pipe on the last couple I have done to get the bleeder out
Here's another pic from another angle
and a pic of the PRV to replace
It looks like the right side is push fitted into the elbow (and the front end is connected to the outlet) but I can't get the b****y thing off!
regards
FOI Balenza - I've just managed to do it
I am not a pratt - I had already consulted techincal at wocester bosch who did say it was easy to replace and didn't really warrant a profesional. As long as I was not messing around with the gas i would be ok. Coupled with my previous post for advice on this forum I gained the confiedence to give it a go.
I just had to pull it slightly more and it came off the outlet and it slipped out of the elbow.
Yes, a little water came out as expected (already had a cloth in place - thanks joineryisahobbynottrade)
The new PRV slotted in its place with no problem. Repressurised system to 1 bar - went outside - no water coming out - sweet.
I will have to change the filling loop next.
Thanks again for the advice
oh, I was quoted £140 from a plumber to supply and fit the part - original WB PRV cost me £10.50 + vat! :D
but you canot change it
Way to save money
Plumbernot, congratulations on changing the PRV ;)
Should do this sharpish as this was the cause of your problem.
wish i lived in manchester at them prices £120 an hour
Way to save money
Like the man in orthopeadic shoes I stnd corrected
Well Done matey
Just an update - I have just changed the filling loop (well part of it)
Had to turn main cold water from outside of house
Discconnected the valve with the key - kept the same olive on the pipework and fitted new valve with new flexi hose.
Turned on water (no leaks)
Pressure spot on at 1 bar - no leak from pipe outside
£2o I paid in total and a very happy bunny :D
I am most grateful for finding this forum and indeed for all the advice I have been given - we got there in the end. 2 weeks ago I didn't have a clue about boilers and today I was able to change the PRV and filling loop thanks to this forum
Keep up the good work and no doubt I shall be using this forum if I have any household problems :p
