Hi there
I recently had an issue with my Worcester 18ri boiler. It kept on trying to ignite and then after a while it would cut out. A plumber said that I had an unstable ignition and said that the gas valve is probably to blame.
The gas valve has been changed, the boiler serviced: cleaned, baffles, seals, electrodes. When the plumber changed the gas valve the boiler sounded like it was trying to get gas to flow when turned on and the green light would turn on for a moment and stop. This would happen 3-4 times and the boiler would cut out. The blue light would then go on then off for 3 seconds. He then did the min and max reset on the gas valve and the system worked all day.
Problem is now after the timer turned off the central heating, it’s doing that gas flow issue thing again but with no green light coming on at all. The boiler will then cut out and do that on and off for 3 seconds thing.
Really confused why this is happening and would appreciate and ideas.
Many thanks.
Many thanks.
