Trying to find out this, if recommended a Monsoon 2 bar single negative pump for my system by Stuart Turner, would there be a down side if I were to use a Monsoon 3 bar single negative pump.
I assume that the flow rate would be the same for both!
What would be the difference apart from the pressure to switch pump off, or would it empty a hot water cylinder quicker for instance.
Many thanks
Many thanks
