I have a Zanussi Aquacycle 1050 and the door will not open. Has anyone got any idea how I can release it as I have a load of washing in it? The cycle has finished but the door will not release.
Has the machine really emptied properly 'most zanussi's have a pressure chamber on the door interlock to prevent the door opening untill it is fully empty.
Check the drain/filter first to make sure the water has all been pumped out and that the pump impeller is not jammed
