A classic I am sure, but I think it's one with a diference.
Let me paint the picture.
Ex-Council building. Huge tank on roof (no access to). Iron pipe that come down to each flat, with a stop cock on. After which a short length of iron, before the first sight of any copper.
Stopcock stuck. Tried various taping, spanners, limescale removers,WD40 etc etc. Still stuck. I can close it a tiny bit, but then I have to hold the collar with a second spaner to stop it unscrewing as I reopen it.
I need to turn it off to change some taps and a few other bits (and no service valves where put in.)
so
1. Can you freeze iron pipes? (guessing they are around 22mm size)
2. Do you need to retap a thread onto them, as I am guess they don't use compression joints?
3. Any experience with council buildings, will they turn off the supply at the tank if I can freeze the pipes, to allow me to carry out the work?
4. Could I just put a new stop cock in at the copper section, and leave the iron stuff be, or is that VERY bad practice?
Cheers people!
so
Cheers people!
