I live in an old terrace and in all the upstairs bedrooms the lathe and plaster ceilings are starting to crack.
I don't think i should overboard them as the lathe and plaster is hanging off small 3" x 1" timbers resting on the upstairs walls. If it's sagging now it's not going to help adding weight to it?
we have nice high ceilings so I'd like to look at building timer stud ceiling to them plaster board over and skim. I'd probably get some extra insulation in at the same time so the only load would be the insulation, plasterboard and plaster.
The middle room the shortest span is 2950
The bigger room the shortest span is 3885
Any advice on timber size and spacing?
