- Joined
- 26 Feb 2015
- Messages
- 4
- Reaction score
- 0
- Country
First post and new to anything DIY.
Moved into our first home, 2007 build and have put up a fair few wall mounted shelves and heavy objects, I'm now stuck with something.
I want to wall mount a book shelf that has 3 tiers and 7 fixing points.
https://secretsales-prod-product-im...139055/1e4eeef4997d38827b2c536181e0485a_l.jpg
The wall is interior and "I think" it's a metal stud wall, however I'm not 100% as I'm new to this. Ideally, if it is I want to hit as many studs as I can for support.
I've been using a magnetic stud finder, mostly to avoid anything I shouldn't be hitting but now I'm more familiar with studs and wanting to mount something heavier I need to find them to hit, especially if it's a metal stud wall.
My main question is, without opening up the wall how the hell can I really tell?
How do I know it's a metal stud or it's a pipe or something else I shouldn't be hitting?
How do I know if the metal stud is actually a metal plate protecting something, it's there as a warning not to drill further?
It's really confusing me. I don't want to damage the wall too much. I've taken a socket plate off to try and see behind but it has a plastic back plate that doesn't look like it can be removed, no screws and there's no gap to see through.
Here's the wall
If I run the magnet from top to bottom of the wall it sticks all the way where the white lines are (right from ceiling to floor), and it's like this every 17.5". The black dots represent where it's a very strong magnetic pull, these are random. At first I figured this could possibly be metal plating joining the studs which is why it was stronger. I'm not sure.
Believing I should hit the metal stud, I took the centre most point having lined up my book shelf previously and drilled, not to pierce the metal but to see what it was beyond the plaster.
You can't really make it out but it's light coloured metal, like aluminium but solid, doesn't really help. But this is what it would be like behind each black circle where magnetism was strongest. I don't know if it's part of the stud or protecting something.
The wall I'm going into is interior and divides 2 bedrooms on the first floor.
I just wish there was an easy way to identify this beyond getting a really expensive stud detector or cutting through the plaster to see properly. I've considered going into the loft but it would still mean cutting through.
I have a wide array of fixtures for this and although I'd ideally like to hit a stud or too, I do have hollow wall anchors winged type fixings for plasterboard. So I could just avoid all metalic pings and just use the plasterboard.
Any thoughts or help here greatly appreciated.[/img]
Here's the wall
