As this is my first post hello to everyone on the forum.
I am planning a stud wall project. Our house dates from around 1900, the room I will be working in is a bedroom and still has the original coving and skirting board. The room previously had a stud wall which I have removed, however the smaller space had been converted into a kitchenette and that space still has hot and cold water pipes and waste disposal, as such we would like to put a shower room in this space.
As the coving is original and made of plaster I would like to do this without removing any if possible, also the head plate will be running parallel to the ceiling joists. In this instance what would be the best way to fix the head plate.
I am also reluctant to remove any of the skirting board. I believe it is original to remove any skirting board. It is original and is attached to the brickwork using wooden wedges that stick into the brickwork. With the coving above and skirting below what would be the best way to place and fix the end studs of the wall?
This is my first stud wall project so if it does seem that I am going about this the wrong way then please tell me.
I have attached two photos, the first shows the skirting board (I will remove the piping and repair the floorboards prior to starting), the second shows the coving.
Thanks in advance,
Roberto.
Thanks in advance,
Roberto.
