Hi
I'm hoping to build a small stud wall in a room where the plasterboard ceiling from floorboard is about 2065mm.
The new wall will have a door and from the calculations I've done it seems I could either cut the door back by about 15mm. Or I could cut out a bit more of the old plasterboard ceiling and fix my top plate directly to the noggins.
The existing plasterboard has already been removed close to the wall on one side so it would only be a bit more to remove but I'm not sure if it would be easier to fit a smaller frame and then chop the door or fix the top plate direct to the ceiling joists/noggins?
EDIT: 2065 not 1065 !! (And tried to make it clearer)
