STUD WALLING PROBLEM
21 Jan 2005
I WANT TO PUT UP A STUD WALL ON TOP OF A UNDERFOOR HEATED FLOOR.
HOW DO I SECURE WITHOUT NAILING/SCREWING. :
Take the Caps lock off, appear to be shouting.
What is the top floor finish, ceramic tiles etc ?
the tiles are are like a bakalite. very brittle.
Okay, best to use Gripfill tube as you say you don't want to damage the underfloor heating.
Is it a wet underfloor system or an electric one? With the latter you should be able to find the cable with a cable finder.
Is the under floor heating still used / connected.
If not, drill away.
If its wanted / still used..
How you expect it too work.?
Use some form of glue (gripfill, no more nails,etc)
