I have a small stud wall to replace/build, the previous one cane down when i took the wardrobed down to find they had been nailed the platerboard to the wardrobe, dont even think you could sat a stud wall existed!!!. What a cowboy job!
So its 96cm length and 292 cm high,
The questions, do i need to put an upright in the middle, i.e at 43cm - 17inch? there isnt a door on this stud but it marries up to a wall with a door,
Do I stagger the noggins for the plasterboard, or just put them straight across every 3ft?
Am i ok to drill a hole in the base plate and top plate and noggins to run elrctrics through?
Ive found one ceiling beam, any idea how far the next beam should be away from the 1st?
Andy
Andy
