Stud work: Is there a standard width?
31 Dec 2005
Cardiff
It's actually lath and plaster walls I'm enquiring about. Reason being, I need to fix a rather heavy towel radiator to an inside wall and the weight of it will probably bring down the lath and plaster (the 'orrible black type :mad: )!!
My plan is to locate the studs and position some horizontal battens (which I am going to t&g over) to fix the radiator to. But how the heck do I find where the studs are? :rolleyes: I have one of these so called stud finders but can't seem to get it to work properly.
This is probably a 'how long is a piece of string' question but Is there a standard width for stud work with lath and plaster walls?
16 inches, that's why some tape measures have markings every 16 inches..
plasterboard is 8' x 4', or it used to be.. so 16" centers would be 0", 16", 32", and 48".
18" would be 0", 18", 36" and 54" = board end drops mid way between studs...
That's why I mentioned that it was a lath and plaster wall built before plasterboard was invented :confused: I thought the distance between studs might've been different back then
So they didn't space them out 18" then as mentioned by Nige F?
:rolleyes:
no way to be certain..
the only way to find them is a fine drill bit and a series of holes at around the 16 and 18 inch marks from a stud already found.. ( the drill will "drop" into the void once through the lath, if it's still going into something then its either a stud.... or a pipe..:)
You may only need to drill one hole, then poke a bit of stiff wire through and feel about.
Can't you hear the studs when you tap the wall with your knuckles?
Tried that JohnD :rolleyes: but it sounds the same all the way across.
I'll have to do a few excavational (is that a word?) holes to be sure.
Thanks everyone :)
